Sk540 Tail Drops In Flight
Discussion in 'Skookum' started by Ozzieheli1, Jun 5, 2014.
By Ozzieheli1 on Jun 5, 2014 at 3:54 PM
  1. Ozzieheli1
    Ozzieheli1 Active Member
    Hi Guys
    anyone know of a cure for this problem
    cg checked e.g. lift by head and checked both directions
    hover test e.g. hillier decay set at 200 test hover low wind
    using specy sats
    always seems to need a touch of forward elevator to keep tail up in flight
    this thing is going to end up as a paper weight
    as same problem on 450- 550 heli reset and reprogramed many times with same problem
    Thanks Bill
      I know this might sound like a stupid thing to say, but it almost seems like whatever method your using to level your swash is not good eunf.. It's hard to diagnose unless it's on the bench, Sound more like a mechanical setup issue to me. Could be gyro related..
    2. Ozzieheli1
      wish that to be the case ,tripod swash level used on all helis. even tried add one turn on elevator to counter act .
      Thing is same helis with Ikon's installed basic wizard setup fly fine .
    3. The Dude
      Bummer, just a thought, never used a Sk540 ..
    4. Ozzieheli1
      no a problem Dude
      tried several H freaks suggestions ; to no avail : just can't work this sucker out. seams ok in all other aspects (basic beginner flying lol)
      just hope the upcoming update may cure it .if not another Ikon May be ordered
    5. BeLoWseaLeVeL
      BeLoWseaLeVeL Member
      I had the same problem with a ttgt5 ended up being the flybarless unit put a vbar on it ,problem solved
    6. Stephen
      Stephen Member
      Does the Heli stay in place in a hover or do you need forward cyclic to hold it in place?
    7. Ozzieheli1
      requires a little forward elevator from take off .Very slow dropping of tail
    8. Stephen
      Stephen Member
      Ok to fix this adjust the subtrim (in the software) of the elevator a little forward till you get a solid hover. Yes the swash may not end up level but this will fix your problem.
    9. Stephen
      Stephen Member
      Did you get this problem sorted out?
    10. beenflying
      beenflying Member
      Sounds a lot like the 3GX backwards drift. I don't have a 540 either, but a common cure for drifting, is to redo your failsafe. If it's different to stick neutral the heli can initialize to the failsafe and then see a different setting on connection to the Tx.
    11. Ozzieheli1
      will hopefully get a chance during the week
    12. Ozzieheli1
      turn out to be radio related . setup new model in dx 8 only to find 5 points of trim by default on every axis
      pity I crash the heli today trying to fly in to much wind for my ability lol.....
    13. smakmeharder
      No way.... is that in the default setup of the transmitter? I had lots of issues with the dx8 but nothing to do with trim.
    14. Ozzieheli1
      yep tried a test setup and checked today 5 points also checked other models 2 out of 5 had same ..don't ever remember using trim on any ..
      might try another test setup tomorrow to confirm
    15. ArgyPak
      ArgyPak Active Member
      Update to the latest firmware. It's fixed a number of issues
    16. Ozzieheli1
      that may have helped also .after update done a hard reset and complete setup with model reset in radio many changes at once to actually know exactly what cured the problem . flew well till I pushed my luck in winds up here (for my ability)
