Notice Accurc Update Available.
Discussion in 'AccuRC SIM' started by HeLiAdIc, Aug 2, 2014.
By HeLiAdIc on Aug 2, 2014 at 1:57 PM
  1. HeLiAdIc
    HeLiAdIc Member
    Latest Updates
    All updates for models, components and the simulator program can be downloaded from this page by clicking on the download links below.
    01/08/2014 - Update Manager
    The update manager will keep your AccuRC simulator updated with the latest version. Please see the readme.txt included in the .zip file for installation instructions.
    http://trasnatech.com/AccuRC-Update-Manager.zip
    01/08/2014 - Dongle Firmware V1.4.3
    • Latency fixes
    • More transmitters supported
    • Improved DSMX support
    • SBUS fixes
    • Channel 8 support
    http://trasnatech.com/AccuRC-Dongle-Firmware.zip
    • Thanks Thanks x 3
    1. HeLiAdIc
      HeLiAdIc Member
      The new update manager fixes a bug with version checking, this will then allow you to download AccuRC version 1.2 and future versions. If you don't use the new download manager it will keep prompting you to update when AccuRC starts.
      Please Note, you must uninstall the previous update manager before installing this new one.
      Changes in this update:
      • Ground in View Camera
      • New camera modes system settings
      • Graphics Optimisations to increase performance on low spec machines
      • Four new servos (KDS BL680 HV, KDS BL690 HV, Align DS615, Align DS655)
      • Two new blades (RJX Vector 600mm, KDS 690mm)
      • One new set of Tail Blades (KDS)
      • One new motor (KDS BL-4725-540)
      • Several new Pulse packs
      • Two new models (T-Rex 600 ESP, T-Rex 700E Flybar)
      • Normalisation code for different transmitters, allows model sharing without throws getting messed up
      • 700 Paddle fixes to increase the model roll / pitch rates
      • Stopped tail booms falling off on model reset
      • Stopped crashes on component change
      • Tickbox to disable battery emulation
      • Increased tail power for all models
      • Tail rotation rate is now specified in degrees per second
      • Crash reset time is now configurable
      • Mouse wheel zoom level is now saved when leaving flight mode
      Download it here. http://trasnatech.com/AccuRC-Update-Manager.zip
      Nice, thank you very much for this
    3. HeLiAdIc
      HeLiAdIc Member
      New features for next accuRC 1.3 update.
      Ohhhhhhhhhhhhh wow.... downloading now.... cant wait...
    5. HeLiAdIc
      HeLiAdIc Member
      AccuRC version 1.3 has been released with various improvements, a new model and scenery. To view the full list of changes please see the support page here. If you have any problems updating you can also download the update patch from here: http://accurc.com/patch_1_3.php
      1. Save the AccuRC_1_3.accurcpatch file somewhere on your hard drive and make a note of where it is.
      2. Open up the AccuRC Updater program, press the patch button and navigate to the AccuRC_1_3.accurcpatch file.
      3. The Updater program will now update your AccuRC simulator to version 1.3.
      Yes I can confirm there are some improvements, mainly visual and also the new flying field. The physics feel slightly better than they were before. This sim is getting better and better...
    7. HeLiAdIc
      HeLiAdIc Member
      1.4 Update announced....
      AccuRC version 1.4 brings several new improvements and additions; We've added a direct controls mode which allows you to turn off the working control system in flight.
      Having no moving controls in flight mode allows AccuRC to run on much lower specification PC's and laptops including dual core processors and lower specification graphics cards, enabling AccuRC's groundbreaking graphics and physics to work without losing all the amazing configuration options and moving controls in workbench.
      Also in this update we've brought night flying to your computer with 4 sceneries and 2 models ready for you to switch out the lights and go fly in the dark, something we'll all be doing in the winter months.
      Headline New Features
      Direct controls mode for lower spec machines - allows the sim to fly without operating the control system.
      4 Night flying sceneries (Beaulieu, Burridge, Disused Runway, Private Airfield)
      2 Night flying helicopters with over 1,800 fully customisable colour schemes EACH! (Synergy E7, Agile 7.2)
      Glow rope random mode - lights flash and change colour whilst you fly - press J to cycle through various options.
      Night Flying Blades (Edge 693's, Edge 105 tail blades)
      Added extra bail out option to recover the model to the nearest horizon (upright / inverted) and added bail out indicators.
      Active Stabilisation mode improved to hold position much better for novice pilots.
      Dongle firmware updater has been integrated into the sim.
      Text pitch gauge overlay.
      Enhancements
      Removed the internal web server to stop sim crashes when computers have malware installed.
      Multiple updates to the user interface to improve the consistency and configuration
      It should be released in the next few hours....... I tried just a minute ago. no luck yet.
    9. HeLiAdIc
      HeLiAdIc Member
      Tried at midnight no luck then either:mad:
