Build Thread Rescued Goblin 630 From The Carbon Pile
Discussion in 'SAB' started by Manyc, Oct 7, 2014.
By Manyc on Oct 7, 2014 at 9:53 AM
    Hello,
    Well what can I say, @BladeBandit had decided to sell a recently crashed Goblin 630 frame... Since it was a steal at the price, even with the broken parts I couldnt walk past it... I will post some pics up later.. but I have plans on making this a night rig, and join the madness that is night flying... Lucky I got most of the parts on the 20% sale...
    Damaged Parts (Will update as I find them)
    2 x BK Servos (not included in the sale.. but one crash took out 2 servos.. youch...)
    Boom
    Main Blade Grip
    Main Blade Grip Arm
    Various pitch links and uni balls
    Tail Fin
    Bearings in tail and head.
    What am I putting in it
    Looking at making this a cheap build.. so here are the parts I have.. and will put in...
    Scorpion 130 opto ESC
    Scorpion 4035 500kv motor
    26t Pulley - Target HS of 2350
    BK coreless tail Servo
    MSH Brain
    Turnigy 4000mah (crappy packs, but only for night flying.. so should be cool)
    Cyclic Servo's ... RJX Servo's
    Night Blades
    Edge 613's ( will need to get lynx conversion bolts)
    Other....
    I will post up some pics of the damage... and as the build progresses, as well as to continue to update the two parts list....
      Ok... autopsy has been completed.. and I must say I am suprised... the tail basically survived.. all shafts were straight... and I cannot believe how tight the bolts were one... I have no idea what @BladeBandit used to tighten them.. but I was using spanners on my screw drivers to get the leverage to get them open. In fact its a testiment to my drivers that no heads where stripped.. cant recommend them enough...
      extra bearings have been ordered... here is hoping I can get all the parts to start working on it...
    2. Stuart
      What drivers do you use...
      I use eds
      http://edsracingproducts.com
      I've used them basically since I started in the hobby getting onto 3 years.. and I've just replaced my first tips... 1.5 mm hex
      They have 120 mm shafts and my local hobby shop sells replacement tips for $5...
      Just found out from @BladeBandit that he used a torque driver for the head... I can't believe I didn't strip the screws
      If you have a 1.5 hex that has held shape after all that time @Manyc and i know how often you check you bolts, you have a real winner - right there!
      you know how much I worked on my 450's... and it was always used to much out bearings and what not.. its been abused to the shiz.. and I only just replaced the tip.. because it was not as nice as I like...
      Well.. it has been revived... the goblin 630... once in happy with how she flies I'll make it into a night flyer..
      [​IMG][​IMG][​IMG][​IMG][​IMG]
    7. 3dmick
      Nice one mate your going to love night flying the 630 has plenty of room for LEDs
      It's going to be sick lol
      Ok.. I can now say the 630 is flying fine as a day flyer tune to convert...
      I'm running low head speed.. flew for 4 min bit super aggressive.. tail tuning funnels piroflips... and came down after 4 min with 50% in the pack
      Also @feral there was no nodding happening at all... was rock solid..
      Yep the 630 looked fine in the air. None of the reported head bobbing..... It flew well.
    10. Manyc
      Ok... after an all nighter... the night conversion is done.. Will post done pics later.. hoping to get her in the air tonight...
    11. legoantstar
      legoantstar New Member
      will you be down at MRCHC? i'll be that way so might drop by...
    12. Manyc
      will be at AFF.. assuming @3dmick doesnt pike before I get there... but I wont be there till 8ish.. so it may not happen..
    13. 3dmick
      It's on like donkey kong
    14. smakmeharder
      ITS ON LIKE DONKEY KONG!!!!!
    15. 3dmick
      It's alive looked great in the night sky well done @Manyc
    16. smakmeharder
      LIght my fire! looks nice... Color scheme is good...
    17. Manyc
      Was interesting doing the whole night flight... going to change some of the colors...
      But it was fun and was starting to get a bit comfortable.. Running a low head speed and having it a bit tamed down for now....
      Looking forward to getting some more in...
    18. hardsy
      hardsy Member
      Looks sweeeeet!!
      So you have flown it at night time??? How did it mess with your brain to start with?
