Breaking News Archeli Turned Off
Discussion in 'Industry News' started by Tedman, Jan 24, 2015.
By Tedman on Jan 24, 2015 at 9:34 PM
  1. Tedman
    Tedman New Member
    Looks like Will has turned off Archeli and Arcplane, time will tell if it will return ?
    //Wayne
    1. jockstrap
      He has already posted that he would be moving it this weekend...
    2. Tedman
      Tedman New Member
      Thanks mate for the info.
    3. jockstrap
      np - well, let's just hope it's only the weekend.
      Will stated in an earlier post that the costs are a concern so he needs to move to a cheaper solution and that there most likely will be
      extended outages this weekend..
      Given the "looking for a new watering hole" message, maybe he hasn't found one yet - could be bad and down longer then..
      As you say - time will tell, but hopefully it's only the weekend :(
    4. Finky
      Finky Member
      the latest post
      All, arcHELI and arcPLANE are going walkabout looking for a new water hole.
      UPDATE - so after working straight through the night - I think (think!) if you are reading this then you are being seamlessly redirected to the new host. Now I have a bunch of back end stuff that needs fixing before I can open the forums - and arcPLANE Will be the first test before arcHELI. 'HELI is proving to be more recalcitrant and I am yet to be able to get it to resolve to the new host. Working on that now. W Will
      The other forum will be fine. Just moving to a cheaper host. Give them a bit of time and it will be online again. Its a pain moving forums....
    6. Servo
      Servo Member
      Anyone know what its called I have asked several times ..and no one seems to answer? ??
    7. simon
      arc heli dot com dot au
      That's it @Heliboy put it all together and replace the dots with dots
      a r c h e l i dot com dot au
    8. HungryHungryHippos
      A ( oystralian )
      R ( Remote )
      C ( Control )
      H ( Helicopters )
      E
      L
      I
      How cheeky, there is a filter on this forum to filter it out, clever.
    9. hgnimda
      hgnimda Ray - Administrator Staff Member
    10. mr_squiggle
      As of half an hour ago the "other" forum is back up & running
