Info Msh Brain Fbl - New Software/firmware 1.0.010/1.3.050 Is Available
Discussion in 'MSH Brain - iKon' started by Manyc, Jan 28, 2015.
By Manyc on Jan 28, 2015 at 3:09 PM
    Looks like a new firmware is out... here are the release notes from Helifreak...
    Release notes:
    - 1.0.010 (firmware 1.3.050)
    - Added Spektrum Binding in software
    - Cyclic Rotational Speeds are now separated for Aileron and Elevator
    - Overspeed after spoolup with some ESC: fixed
    - Dynamic headspeed management during extreme overspeed maneuvers added
    - Random hot start on startup on some ESC: fixed
    - Governor precompensation optimization
    - Added tail drag precompensation
    - Added Cyclic Pitch Pump
    - Added swashplate design in radio setup for see the servo number position
    - In wizard (panel 7) doubled the resolution in swashplate setup
    - Factory default "Tail Dynamics" is now at 6% (easier on TT transmissions)
    - In Model Size Selection (panel 11) Elevator preset D Gain raised
    - Governor: Deadzone range raised now at 0-350
    - Bailout ramp range raised now at 0-140
    - Removed JR trademark from drop down menu and also from swashplate selection
    - Added in cyclic setup instruction "10 degree"
    - Minimum and Maximum throttle pulse width for the esc, is visible also in the Wizard
    - "Motor is Electric" check now is also in the Wizard, now “Electric motor” is default
    - Inserting, complete, correction, of texts.
    - Overall optimization and bug fixes (Cyclic Ring, Feed Forward, etc.)
    Setting changes to do from previous version :
    - Set the new Rotational Speed
    - VERY IMPORTANT Verify the cyclic rates separately for ail/elv before flying in each bank
    Rates for ail/elev are in Advanced->setup1-2-3->cyclic
    Android version will follow in about 2 weeks, we decided to not hold the new firmware and release for windows and have people enjoy it even if Android not out yet.
    Please use it and let us know what you think.
    As usual free to all users as it will always be............
    Thanks for waiting and hope you will like flying it as much as we liked it writing and testing it for you.
    Special thanks to all our dev and test team.
    Special thanks to Alex Rose AKA OnTheSnap.
    Corrado
    1. hgnimda
      hgnimda Ray - Administrator Staff Member
    2. Manyc
      From Helifreak.... http://www.helifreak.com/showthread.php?t=678506
      WooHoo!!
      Hope you guys love this firmware as much as I do. :)
      A few things that may help -
      1) As mentioned by Corrado, double check elevator/aileron rotational rates in each setup to make sure they are what you expect
      2) For tail drag compensation I find -6 is good for most model sizes. You can test it by doing side in climb outs upright/inverted and watching the boom angle. Flat or a tiny amount of lag is ideal. You don't want more than you need.
      3) Pitch Pump - Well this is the ultimate tool for hard smack. And also helps a lot on the small heli's too where there is less collective authority. For a serious pop and lock session, I like about 40 on this. Becomes silly fun in hard stops and tic tocs where collective becomes very easy to manage. It doesn't impact precision and is really implemented in a brilliant way
      4) Governor updates are HUGE in this update. Take the time to re-address your governor settings to make sure they are optimized. Defaults are still pretty good. If you like the overspeed high energy stuff like I do, the Brain is industry leading now in terms of how it dynamically manages headspeed recovery. More precisely, after you overspeed and load the head there is ZERO recovery time to the set headspeed. It's simply brilliant. McDoogle away. The changes made in feed forward and overspeed management also greatly improved the RPM holding capability of the Brain governor. My heli's all feel far more powerful now.
      5) Auto-rotation bail out - I use about 90 on the bail out ramp now. Or sometime higher. Now the headspeed comes back on MUCH faster. So doing blade stop fakies and getting the power back on before you plow is stress free.
      Have fun!
      Did some one say PITCH PUMP?????
    4. Ozzieheli1
      Ozzieheli1 Active Member
      Will wait awhile, seams to have a few small issues at the moment.
      Do you know what those issues are? Anything serious?
    6. Ozzieheli1
      more to do with blue tooth connectivity and programming with same...eg serial interface.
      I am waiting till I start to see some good reviews !
    7. Manyc
      I've seen a few... I'll upgrade mine for the weekend and let you know.. I connect via pc and not Bluetooth
      Looks like they have already released the fix.. seems the file was corrupt on the server
      Nice one @Manyc, thank you
      Anymore updates on the firmware since the weekend? How does it feel when flying @Manyc, do you notice much difference?
    11. Manyc
      I haven't enabled any of the new functions.. ie pitch pump... but the governor has seemed to improve.. however the weekend was so shiz weather wise it was hard to tell...
      Are you coming down this weekend? If so we can play around a bit? with the pitch pump i mean... I am very intrigued how this function will operate when doing piroflips. I remember in the beastx it was one of the things I loved....
    13. Manyc
      Should be down on the weekend... now all my fbl have pitch pump :)
    14. Ozzieheli1
      any updates guys ,have played with it on spare unit and thinking of doing the others....
    15. Manyc
      Upgrade it worth it..some of the new features are nice and if you are running a gov it's worth it just for that... Just remember because they made the flip and roll rates independent you will need to go back and set them... Else they must likely will default to 0 and then your in trouble. You will need to do this for each bank...
    16. Ozzieheli1
      Bit the bullet updated 450 and now waiting for no flaming wind to test
    17. Manyc
      Double check the roll and flip rates.. Else you could be in trouble...
      I have updated my trex 700 and mini protos both fly fine..
    18. Ozzieheli1
      if memory serves me correctly they are both at 150 but will check again.
    19. Ozzieheli1
      Found after update .reload configuration file / recheck heli size and flying style .tabs 11/12 will set the missing parameters .still requires a few more tweaks but is this not part of the challenge.
