Xnova 4025 Bearings X 3
Discussion in 'XNOVA' started by ChopsyWA, Mar 5, 2015.
By ChopsyWA on Mar 5, 2015 at 11:29 PM
  1. ChopsyWA
    Hi all,
    Just a bit of info in case you have to change the bearings in your Xnova 4025, there is actually 3 bearings in the motor, not 2.
    The early version apparently had 2 bearings, but it has been updated to be like the 4030+ series.
    I came across this having needed to do a bearing change post Goblin 570 write-off, having ordered a bearing pack for this size motor b4 taking it apart, to find it contained 2 bearings in the pack when the motor has 3.
    Many shops may still shelve the original 2 x bearing packs, and even the Xnova website still words "NMB bearings (2)".
    Cheers
    • Like Like x 3
