Review Review Xnova Xts 3215-930kv Tareq Edition Goblin 380
Discussion in 'XNOVA' started by HeliGods, May 5, 2015.
By HeliGods on May 5, 2015 at 1:00 PM
  1. HeliGods
    Well after already trying out two different Xnovas motors, I was sold. So i fitted an Xnova XTS 3215-930KV TAREQ EDITION to my Goblin 380. As i expected WOW ! A very smooth running motor with Raw unboggable power at all head speeds.
    The motor sure ticks all the box's, More flight times due to the superb efficiency, Super kewl temps, (less heat) Making it very efficient and easier on the packs (Longer pack life), High quality windings, High performance stator metal , High quality NMB bearings, Simply put quality thru and thru and if that ain't enough they also look Sexy ! ... I don't want to sound biased, but i just cant find anything i would fault on this motor, it's really that good !
    Xnova also have the 2820-890KV for long flights that don't take away from the power of the XTS line. If your after RAW unboggable power then try out the Tareq Alsaadi version with a slightly larger stator and a slightly higher KV value at 3215-930KV, and lots of power!!
    Xnova XTS 3215-930KV TAREQ EDITION (for Goblin 380)
    Designed for "EXTREME" 3D flying AND good flight times, specially made for your SAB-Goblin 380 where highest power to weight ratio is important. Xnova carefully optimized and tested this Motor along with world renowned pilot TAREQ ALSAADI under Extreme flight conditions.We all know when he smacks a heli it has to perform !!
    Features
    1. High qual. Neodym Mag.heat res. up to 150 degree C (302 degree F).
    2. Specialized wires,heat resistance up to 250 degree C (482 degree F).
    3. Precise balanced.
    4. High performance stator metal sheet.
    5. High quality NMB bearings.
    6. Marked leading high efficiency up to 90%.
    7. Cooler running.
    8. Superb quality and machining of CNC parts.
    9. Improved torque and power output.
    10. Hand wound single strand wire
    SPECS:
    Slots & Poles 12n10p
    Winding T
    YY
    rpm/V
    930
    Volt (V)
    10 / 22.2
    Io(A)
    1.3 / 2.1
    Rm (mohm)
    28 / 28
    Weight (without connector) (g)
    160
    Body Length (no shaft) mm
    40
    Diameter (mm)
    40.5
    Shaft Length (mm) (Details pictures)
    A
    Shaft Dia. (mm)
    5
    Mounting Holes CTC Distance (mm)
    25
    Mounting Screw
    M3x0.5
    Max Eff. Curr.
    21.55 / 40.80
    Max Eff.
    87.93 / 89.71
    Kt (Nm/A
    0.0103
    Km (Nm/sqrt(w))
    0.0614
    Max Continuous Power(Watts)
    1280
    Peak Continuous Power(Watts) (2 sec)
    1700
    Max Continuous Current(Amps)
    58
      Well I am going to find out very shortly how it goes.....
    2. feral
      I used to get nailed on the other forum when I suggested Xnova's and that was before I was part of the team I'm glad you dudes are loving Xnova.
      Unbiased reviews like this make the team proud to be a part of it all
      Well done dudes happy smackin
      You will always get nailed on all forums @feral , life is just not fair... LOL
    4. feral
      Lol thanks for the positive reinforcement @simon theres way to many HK professionals on that 1 I like this place way more
      Welcome to the club...
    6. The Dude
      @smakmeharder 's buddy with the Xnova Xts 3215-930kv Tareq Edition Goblin 380
      NICE POWER !!!! Sound like an angry pissed off BEE !
      Xnova's are such good motors, why would you want anything else !
