Question? 2016 Wish List For Rc Heli Manufactures
Discussion in 'The Chat Room' started by The Dude, Oct 7, 2015.
By The Dude on Oct 7, 2015 at 10:58 PM
    What would you like to see come out in 2016 ?
    1:/ Protos 500 V2 with dual belt drive and metal head and tail for me .. With the option of a stretch included in the KIT !
    2:/ Thunder Tiger e700 model in Accurc
    3:/ Removable servo wires standard on all servos, Like the Xpert full size servos have.
    4:/ An adjustable collar system setup for servo horns like the ones JR and Thunder Tiger have.
    And your wish list is ?
      Okay this is what i would want. A 700 machine that you could absolutely cane the hell out of it without fear of breaking. This machine should be light - look really sexy - be very very strong and assemble as easily as the goblin 380. The power train should be infinite. The maintenance should be little and obvious. Service should be around 500 flights where over strength bearings /belts are still coping with the load. The flight characteristics should be similar to a TDR. The parts can be a bit more expensive than normal because it doesnt crash due to mechanical failure. The geometry of the swash is perfect. The tail holds like nothing else - ie you can throw the heli into any position at any speed and the tail will hold. I would also like the feature to insert a battery very quickly and securely without having to remove any canopy. Some sort of quick release feature. It must also look very tough.
      Are you listening @HeliGod Father?
    2. HeliGod Father
      HeliGod Father Administrator Staff Member
      Yes @smakmeharder I hear your call. The heligods discussing this with the major heli vendors as we speak. However we cant come to agreeance because @Crash Heligod has the deciding vote. Will keep you posted on events...
    3. Crash Heligod
      I a 700 class heli with thin glass frames, putty hex screws, dry solder joints, wooden blades made from balsa wood, hawk ESC, hobbyking batteries, xt60 connectors, thin light weight battery wires, Chinese bearings, superglue for loctite, belts made from twine and canopies made from the same material the eflight use. The motor should be incredibly overpowered and the blades should run +/- 16 degrees pitch and potentially spin at 2500 rpm. The receiver and transmitter should at least be the orange variety. Bring it on!!!!
