Gaui TSH Gaui Eclipse E28f Open Box Hd
Discussion in 'Gaui TSH' started by The Informer, Feb 11, 2016.
By The Informer on Feb 11, 2016 at 3:15 AM
  1. The Informer
    The Informer Administrator
      I want, nice looking bit of kit
      Does not look too bad. What do you think of this @Manyc seeing you and @ArkRC (josh) are the closest thing i have to the racers at the moment....
      @BladeBandit is probably the better one to ask.. From the looks, the intergrated PDB board and controler is nice, but I don't see any OSD in there.. also I am not sure I am a fan of the tube arms, it the ESC's are meant to be housed in there, I would worry about heat.. dont know if they make ay difference or not. Having tiltable motors mounts is nice.. but not really needed with the fpv camera being able to be tilted, especially by a servo. Battery tray is nice.. but seeing its on the top, just a strap out be fine.. cant really tell much from the video.. when one is seen in real life will be interesting.. I think the RX is mean to go under the top.. but it doesnt look like there is much room for more that you small FRSKY type RX.. not sure if you could fit a RS6303SB in there...
      will be interesting to see one in the flesh
      Another Vid...Looks quick but some real figures would be nice.
