Wait For It -
Discussion in 'Speed Helicopters' started by Robert Gorham, Mar 13, 2016.
By Robert Gorham on Mar 13, 2016 at 12:53 PM
  1. Robert Gorham
    Robert Gorham Member
      AWESOME
    2. iggy
      ROAD RUNNER. - Miig miig!!
    3. Geena
      WOW! With runs like that, you`ll soon be giving Justin Pucci a run for his money.
      NEEEEAWWWWW!!!!! Wow that was close to the ground!!!!!!!!!!!!!!!
    5. Crash Heligod
      Not low enough! Needs to be another meter on the deck (muah ha ha ha)...
      Just imagine clipping a skid on the deck at speed, you'd be picking up bits for hundreds of meters
      • Funny Funny x 2
      Yeah seriously one little clip of anything at that speed - it would be all over (the place). I have to admire the guts of @Robert Gorham . Its very hard to fly with precision at speed - 1mm on the sticks can be the difference between elation or depression! There would be very little left after any incident like that.
    8. Robert Gorham
      I am by no means a speed expert but I learned very quickly that smoothness on the sticks is the key. I think all my F3C training when I was younger is helping me out with speed flying. F3C is nothing but total precision, can be frustrating at times however it makes for a better pilot. Thanks for the kind words Shakmeharder. Appreciate it.
    9. Robert Gorham
      Here is a Castle log from a 3.5 minute speed flight that makes this R5 go for those of you that like this kind of stuff.
      • Like Like x 3
    10. Robert Gorham
      It's time to make her go faster with the new release Scorpion 4235 630 KV motor.
      Wow, here are the motor specs!!!
      Stator Diameter 42 mm (1.65 in)
      Stator Thickness 35 mm (1.38 in)
      No. of Stator Arms 12
      No. of Stator Poles 10
      Motor Wind 4 Turn YY
      Motor Wire 1-Strand 1.6 mm
      Motor Kv 630 KV RPM/Volt
      No-Load Current (Io/10V) 3.59 Amps
      Motor Resistance (RM) 0.009 Ohms
      Max Continuous Current 120 Amps
      Max Continuous Power 5328 Watts
      Weight 522 Grams (18.27 oz)
      Outside Diameter 52.3 mm (2.06 in)
      Shaft Diameter 5.98 mm (0.24 in)
      Body Length 64.5 mm (2.54 in)
      Overall Shaft Length 112.9 mm (4.44 in)
      Max Lipo Cell 12s
      Max Peak Current 160 Amps (3 seconds)
      Max Peak Power 7100 Watts (3 seconds)
      Motor Timing 5deg to 15 deg
      Drive Frequency 8kHz
      If you dont mind me asking, what speedy are you using in this beasty? This motor will peak at 160 AMPS for three seconds according to the specs.. seems almost like you need a 200amp to be sure?
    12. simon
      I know a 120HV castle can peak at 160+ on the logs..
    13. Robert Gorham
      I'm spinning 3250 HS and only pulling 129 amps Max. I'm using a Castle 120 EDGE HV ESC with an added fan to keep it cool.
    14. ScottE
      ScottE Active Member
      Hi @Robert Gorham ... ex-speed freak & about to get back into heils again ( 238 KMH with a faifa). What sort of top speed have you been getting with that beasty ? producing nearly 5Kw that R5 would be really moving like 240 Kmh ?? . Im just about to start rebuilding an monstro E need esc, motor & blades --- anybody got sme unused bits LOL sorry to hijack your thread mate
      Scott
    15. Robert Gorham
      With the old Scorpion motor (4525 520 kv) on the straight and level I was averaging 225 km/h. I have not clocked the R5 with the new 630 kv motor as of yet however 240 km/h should be reachable.
    16. simon
    17. smakmeharder
      DUDE! I was sipping my coffee on that first pass and spilt it all on my lap!!!!! far out!!!! That was INSANEEEEE I love how you fly....
      Wow! Don't put pictures like that in my head! :eek:
    19. Beaver
      Daaaayum!! :eek:
