Just got back from trying out my Goblin 420. I only had 1800ma packs so flight times were around 2mins 15 seconds.
I put through about 6 packs at the swamp with winds gusting at around 20 Knots.
OBSERVATIONS:
Very fast - stupidly fast - it might have something to do with the fact that i only had 1800ma packs plugged in. Absolutely insane pop... Really something to get excited about. It also feels a little slippery. I think this will tame down just enough when i add another 700ma to the packs which will CG the heli correctly then.
It felt like a much much bigger heli. It was still solid in the air as well. It is also very fast in forward/tailfirst flight.
BUT It sucks batteries! My packs are tired but i think this heli identified 3 weak packs in my arsenal of 9 packs. It definitely sucks the amps. But the XNOVA Tareq motor doesnt have a problem supplying the torque. Typical flight time using 1800 packs was 2min 15 seconds.
The Hangtime is definitely better. Piro tick tocks just sit... And INSANE rainbows and pogos. To be fair the piro flips felt a bit off, i had to slow them down to keep them pinned... but its not CG properly yet it NEEDS heavier packs.
MY FEELING:
Yes... Yes..... YES YES - I LOVE IT SO FAR. Its still early days but i feel like a kid with a new toy. You need around 2.5 amp 6s packs to drive this baby flying hard 3d for a solid 3 mins. I Still need to tune it properly - I just used my settings from the 380 and turned the engine down 80%. So i could probably drop a pinion size and go up to 90% throttle to improve efficiency and torque.
I feel this heli has alot to offer and definitely recommend the upgrade for a totally different feeling heli.
WHAT I WOULD LIKE:
A wider choice of blades. Having just the SABs is not my preference mainly due to availability. Either aftermarket bladegrips that take 500 size blades (Mr Lynx?) or Bert, Zeal and Halo come to the 420 party.
A RED canopy and BOOM. Red and black are my fav colors... Green looks ok but its not my thing. Its gotta be red...
BATTERIES! FOR GODSAKES GOOD QUALITY BATTERIES. Only option is OS at the moment.
I would like 2.5 AMP at 200C (well I would settle for 60C)
Info Goblin 420 - N.i.c.e
Discussion in 'The Chat Room' started by smakmeharder, Jan 11, 2017.
Tags:
