Upgrade's The Vbar Neo "cage"
Discussion in 'Vbar' started by ChopsyWA, Nov 25, 2016.
By ChopsyWA on Nov 25, 2016 at 1:22 AM
  1. ChopsyWA
    Alrighty, check this out ladies & gents.
    The Neo Cage, manufactured by Charlie at 3DME in Western Australia.
    Consist of a top & bottom plate, two plastic standoff's and two screws.
    The bottom plate is double sided taped to the heli, and the Neo is held between the top & bottom plate.
    The rear standoff acts as a servo cable retainer.
    So far Charlie has around 50 flights and counting. No increased vibration or any other issues to date.
    I will be fitting mine this weekend on the Logo 700 to bang out a heap of test flights.
    https://3dminiatureengineering.com/products/vbar-neo-cage
  • Tags:
    1. Ozzy Mozzy
      Ozzy Mozzy Well-Known Member
      Looks great and a smart design.... I'll be getting one for sure.
      For all the NEO nazis this should be a bonus...
    3. ChopsyWA
      Dozen flights testing the Cage this morning on the logo700.
      Working excellent!
      Will be hitting up Charlie for some more units to fit to all my helis ;)
    4. HeliGod Father
      HeliGod Father Administrator Staff Member
      Absolutely magnificent my heli-brother...
    5. Ozzy Mozzy
      I have one on order but I can see that I'm going to want more.....
    6. ChopsyWA
      FYI: I checked the vibration of my Logo 700 on the bench no blades before and after fitting the Cage - no increase whatsoever.
      When you think about the Cage is an extension of the plastic case, with double sided tape between the Cage and heli instead of between the plastic case and heli.
      The Cage to Neo connection is rigid, but the Cage to heli connection is dampened with the same DS tape as before.
      And no static effecting the Neo thru the Cage. My logo 700 definitely has static, but with earthing wire the Cage basically becomes a faraday cage ;)
    7. ChopsyWA
      Chris Reibert review.
    8. Ozzy Mozzy
      Received my NEO Cage yesterday....
      Fitted the Cage to my HD750
