VERY IMPORTANT INFORMATION - CHECK YOUR MODELS IF YOU HAVE A CGY750.
Tech Notice for CGY-750 users!
Standard S.Bus servos and gyros should NOT be connected to the S.Bus2 ports on any receiver.
The CGY-750 must only be used in an S.Bus-designated slot in the receivers. DO NOT attempt to use in any S.Bus2-designated slot. Doing so can possibly cause a reset in flight and result in a crash. The CGY-750 does not support S.Bus2.
If you have any questions, please email Futaba Support at support@futabarc.com.
Notice Cgy 750 Advisory
Discussion in 'Futaba CGY750 FBL System' started by smakmeharder, May 6, 2017.
