Question? 630c Tuning
Discussion in 'The Chat Room' started by iggy, Sep 24, 2017.
By iggy on Sep 24, 2017 at 11:15 PM
    Hi people
    I just bought a 630 Competition Goblin and want to do some tuning.
    Can I use the matte black head and tail systems from the Black Thunder for this model? Or where else is some compatibility in question of spare parts, landing gear or even fuselage?
    I want to use my motor setup from the mikado logo with a Jive 120hv, Pyro 700-52
    3300 or 3500 mah packs maybe with a 22T motor pulley. Flight time will be? 2:30 to 3:00 minutes with some smack?
    I dont like the logo 600 sx. Back to SAB. I know some of you fly Goblins so you might know more about this topic.
    Thank you guys.
    iggy
      I will check out for you. I know a Sab Dealer....
      OK i found out from Mr ZEN RC (www.zenrc.com.au) himself! Here you go @iggy
      Yeah the head will be a straight swap because the maim shaft is same diameter. He might need to do a bit of messing aroumd with linkages etc ro get the setup right but it can be done. Also, because he'll be using a 700 size head, the rotor diameter will increase slightly.
      So i hope that helps....Sean knows everything about SAB goblin (and many other helis as well)
    3. iggy
      Man @smakmeharder thank you very much. I thought the mainhead of the 630 700 and 770 are the same size and i got to change only blades and tailboom for a strech for example.
      Do you think that I got to mess around with the linkages if I use the head and swash from the BT?
      Cheers
    4. iggy
      Lets get this party started.. :)
      Hey Very nice @iggy Sean informed me that there will be a bit of playing around with linkage length - but you have to do that anyway. Its looking good!
    6. ChopDrifter
      ChopDrifter Member
      Looking good iggy
    7. iggy
      Ready for software setup.. :)
      20171007_171514.jpg 20171007_171855.jpg 20171007_171647.jpg 20171007_171952.jpg 20171007_171802.jpg
    8. ChopDrifter
      ChopDrifter Member
      nice clean wiring
    9. iggy
      Yeah @ChopDrifter I take allways time for this. Clean wiring, greasing the bearings, doing a perfect mechanical setup. I even pulled the motor apart, cleaned it and greased the bearings. Now Im waiting for the brain/ikon bluetooth module. Maiden flight will be soon.
    10. iggy
      Sending from the field in Zürich Switzerland. Got around 20 flights in with the new machine. Feels better and better as i get used to. For me the perfect size heli. Its big enough and fits in every car. Getting 3-4 minutes flight time with 3300 and 3500 12S setup. Very nice standard setup from the new msh brain firmware for the V2 (Brain 1). Have to mess around with the swash gain and tail precomp just a little bit. And maybe change the mainblades. But im very happy. Oh I forgott.. its only funny with 2350 rpm headspeed. Everything unterneath is kind of boring ;)
    11. ChopDrifter
      ChopDrifter Member
      very nice
    12. iggy
      Wanted harder blades for my 630..
    13. helitone
      helitone Member
      awesome
