Question? Backup Battery For Yge Esc Bec Vs Separate Voltage Regulator?
Discussion in 'YGE' started by HungryHungryHippos, Feb 23, 2015.
By HungryHungryHippos on Feb 23, 2015 at 10:13 AM
  1. HungryHungryHippos
    Has anyone used a separate RX battery as a backup for the BEC on a YGE speed controller?
    The manual says, if your using the 5.7 volt BEC setting, to just use a NiMH 4 cell battery directly into the receiver port.
    I would imagine the main reason for using this is incase your main battery dies or the esc over heats etc.
    Is a backup battery effective? or is someone better of snipping the red wire and using a separate RX pack and voltage regulator?
    1. HeliGods
      Snipping the red wire and using a separate RX pack and voltage regulator, is how i went with it, back when i used YGE's
    2. Captain
      Captain Active Member
      If you use an RX pack then whats the purpose of the BEC?
    3. HeliGods
      Doh ! .. Cut and past .. did not use RX pack.. Good point.. Just BEC .. Thanks for picking that up.
    4. HungryHungryHippos
      The using RX battery with BEC had me stumped as well.
      From what I have read, the RX battery is meant to be used as a buffer pack or backup. I suspect this is incase if there is some type of calamity with the ESC , the RX battery will give you servo control to auto rotate land your helicopter.
      However, in practice, I was flying a logo upside down when the ESC decided to go pffffft. I had a separate RX / voltage regulator for the servos.
      But, once I flipped it up right, it was over bushland at that stage, so I couldn't see it when it got behind some bushes, so I did damage it.
      In this case the separate RX battery and voltage receiver did kind off help.
      I suspect, regardless, of separate RX pack or not, if its going in, its going in.
    5. Manyc
      If you use a BEC I would always use some form of backup to make sure in the event of a esc/bec failure. I generally run a Backup Guard. The buffer pack can be used the same way, but it will also charge off the main flight pack... as well as being a buffer in the event of a huge current draw from the servo's.
      but except for my 450, if it runs a bec, it has some form of backup.
