News Oxy Heli
Discussion in 'Industry News' started by Richard Knapp, Oct 21, 2017.
By Richard Knapp on Oct 21, 2017 at 7:47 AM
  1. Richard Knapp
    Richard Knapp Active Member
    Luca:
    Something new come assembly in my desk!! And is not the 2!!
      Hmmmmm. I wonder what it could be! I like the over/under pitch control fork- cant see the pitch control leaver from this position so i am not sure where the pushrod is. Why is the pully on what appears to be the back of the helicopter?
    2. Richard Knapp
      If you look at the belt. The heli is nose right.
      Tensioner is belt eatery to the boom.
      AHHH i was looking from the wrong angle... now i see! I like the idea of the pully next to the tail gear because in theory you can run the belt looser for less friction overall.
    4. Richard Knapp
      On site now
      OXY2 - 210 FACTORY EDITION
    5. ChopDrifter
      ChopDrifter Member
    6. Richard Knapp
      SP-OXY2-108 - OXY2 Canopy Schema #3
    7. ChopDrifter
      ChopDrifter Member
      personal taste I guess, but I like this blue canopy scheme
    8. Mat
      Mat New Member
      Please give us more O4 pics, and oh I hope schema 3 canopy will also be available with it. Spot on
    9. Richard Knapp
      I will as I get them.
    10. Richard Knapp
      NEW LOWER price.
      OXY3-255 - Oxy 3 Helicopter Kit 255 mm Main Blade
      Price : $204.25
    11. Mat
      Mat New Member
      Awesome pricing, and thanks Rich for the photo updates. Any rough estimate yet on release, i.e. Before Christmas?
    12. Richard Knapp
      Dear OXY 2 pilots:
      I would like to explain why we made the straight main gear for oxy 2.
      The most important thing is to explain that are related to oxy 2 190 Sport.
      Main gears are not slant and are not CNC.
      They are injected mold to reduce cost. This is why they are a straight instead of slant.
      Now
      The Sport main gear can also use on any FE with the straight cut pinions.
      Because any FE as upgraded kit, it has the upgrades CNC slant main gear as Std.
      If people are looking for a low-cost solution to fly any OXY 2 FE. They can use the injected one on the FE they just need change the pinion to a straight cut.
      Also about pinion we now made things easier.
      We decided to make bag set of pinions with the common similar sizes.
      Now we have slant and straight in both the 2 and 2.5 mm.
      Now available.
      The pinion with 2 mm shaft are released for higher kv motor.
      Than we made the pinion options with 1 tooth difference.
      The ones with 2.5 mm motor shaft are related to lower kv motor and we had no need to have all different number tooth.
      We tested and there is no need have them all.
      That why we offer some tooth for 2.5 mm shaft but not all.
      We offer the 2.5 mm shaft in 2 tooth difference that is ok.
      Thank you.
      Luca.
    13. Richard Knapp
      The OXY 2 190 FE is out now along with the canopy's posted.
      The Sport will be out withing the month.
      Ah! Nice photo. That arrangement definitely increases the tooth contact around the tail pulley..... reminds me of my Mini Protos with the larger diameter tail shaft pulley. :D
    15. Richard Knapp
    16. ChopDrifter
      ChopDrifter Member
    17. Richard Knapp
      Per Luca:
      "Hei Folk.. after long silence I am here to speach.. hahhah
      I want share with you some important and exhiting news.
      I am in Saigon airport waiting some top european pilots that will stay here with me and my family.
      Main purpose of this trip is OXY 4 final Test.. and for sure some good relax!
      We will collect last missing oxy4 testing data and be able to finalize this new amazing and creazy performat 450 sized OXY HELI.
      More info will follow..stay tuned
      PS. In this critical and slow turn heli busness momemt, I want, one more time, say thanks to all of you that understand, appreciate and support our job.."
    18. helitone
      helitone Member
      Take your time Luca, Iron out all the bugs, I am willing to wait for a perfect Oxy4
    19. Beaver
      450 you say??? :D
