Info Protos 380!!
Discussion in 'MS Heli' started by Ozzy Mozzy, May 24, 2016.
By Ozzy Mozzy on May 24, 2016 at 8:07 AM
  1. Ozzy Mozzy
    Ozzy Mozzy Well-Known Member
    Looks like MSH have been busy....... Here is a copy and paste from HF
    The Protos 380 is almost here. We wanted to give you guys a first look at this _amazing_ machine.
    We will release more details soon, but here are a few of the specifications:
    Up to 380mm size disk
    Standard and Evoluzione versions available
    Includes miniBrain2 (full featured, yet incredibly small footprint. Includes new processor, logging, and rescue features)
    Twin belt design, with robust OWB located in the main pulley assembly
    Auto tail belt tension mechanism
    Huge gear ratio range making it compatible with very power system configuration
    Very low disk loading with a very high vertical CG. Giving it unmatched flight performance and feel
    1. Ozzy Mozzy
      More info........ another copy and paste from HF
      Easily 4:30 at 3000RPM with 6s1800mah. 3200 RPM is insane since it's a very light model. I think most guys wanting hard 3D will be happy at 3000 with this model.
      All my testing has been done with this motor and the 26xx Xnova. Any motor will work though. It's extremely flexible. I think the Xnova 2820-890kv is the perfect match. Insane power and great efficiency. With 1800mah 6s packs I'm really happy with the flight times.
    2. Black Knight
      Black Knight New Member
      It's looking pretty sweet :)
    3. maingeer
      very nice, I hope arkrc.com.au would be having this in stock one day???
      Ah! Nice! Dual belt drive..... we need more like this! I dont like gear noise. :D
      Im drooling...... so many fond memories of the 450 miniprotos..... (which i still have)
    6. joeclone
      joeclone Active Member
      Loving this size of heli, just hope it dun inherit belt problems from the mini.
    7. Ozzy Mozzy
      I like it..... This might take over from my G380 :D
      I cant see that being the case @joeclone ... The protos 380 has a two stage belt meaning it should be able to absorb massive power. The problems from the original minip was mainly due to not being able to handle the higher power dished out by the newer motors. Using the origninal motors you could normally thrash throug 150 flights before changing belts. The goblin 380 however redifined this limit with up to 400+ flights using original belts...
    9. Manyc
      From what I have looked at, this is a complete redesign.. you cannot upgrade the mini p to the protos 380... you are buying a whole new kit and shelving the mini p.. I can tell you now.. I will be getting one
    10. Hellifun
      Hellifun Active Member
      that's very awesome!!!
    11. Manyc
      dammit.. could they just do turnbuckles and be done...
    12. joeclone
      So wassup with the msh power bus? Cleaning up wiring?
    13. Manyc
      pretty much.. something similar to what GAUI did with the X3, and MSH did with the MAX, but like the max, is not incorporated into the frame, unlike GAUI... reports on it from the MAX are very good, and that it doesnt break on a crash.. I think I will give it a shot
    14. Ozzy Mozzy
      I'm keen!!! I take it Ark will be getting these in...... Where is Josh!
    15. Beaver
      (Which I may one day attempt to convince you that you should sell to me. :p)
    16. Manyc
      I am sure he will be all over it when it comes out.. but I think it would be several months away at least... thats my opinion based on no facts what so ever
    17. gonehelimad
      gonehelimad Active Member
      This is the perfect park beater I have always wanted.
      Cant wait!!!!
    18. Black Knight
      We can always use some more "park beaters" in the world :)
    19. Ozzy Mozzy
      2nd Flight!!
      • Like Like x 3
      • Crash Immunity Crash Immunity x 1
