Upgrade's Synergy E5 Magnetic Mounts Mod
Discussion in 'Synergy' started by Ozzy Mozzy, Jan 22, 2016.
By Ozzy Mozzy on Jan 22, 2016 at 8:35 PM
  1. Ozzy Mozzy
    Ozzy Mozzy Well-Known Member
    Just thought i would share what I did for Magnetic mounts on my Synergy e5 Canopy.
    Dennis put me on to the Protos MaxV2 magnetic mounts. So i dropped into ARKRC and picked up a set.
    www.arkrc.com.au/magnetic-canopy-mounts-qty-2-max-v2
    The base that mounts to the fame is too long, so I cut off 8mm.
    With a 2.5mm drill bit I drilled down the center till I got to the side hole. That seemed enough for the mounting screw.
    I then mounted it to the frame in the same spot of the synergy ones.....
    Mounting the magnet to the canopy I used a shock piston off a Baja 5b..... the inner hole was the right size for the magnet to sit into and worked as a big washer on the outside..... It was also the right thickness!!
    It worked out to be perfect!!! Not sure if ill put some at the rear of the canopy yet. But I think it would easier to do.
    1. Stuart
      Awesome mod.. I've been wondering about magnetic clasps. What is a Baja 5b?
      Stuart
      Citizen #507
    2. Ozzy Mozzy
      Sorry I should have been more specific.... It's a 1/5th scale off-road buggy made by HPI.
      The shock piston is a good size!!! I had a couple of spares, so it was easy for me.....
    3. Manyc
      Maybe list out the dimensions.. Might be able to get Josh to 3d print something that would fit
    4. Ozzy Mozzy
      Yeah good idea!!!
      3.5mm thick
      5mm I.D
      16mm O.D
    5. Stuart
      Print me some josh
      Stuart
      Citizen #507
