Tareq Alsaadi New Oxy3 Tareq Edition V2 2018
Discussion in 'Tareq Alsaadi' started by The Informer, Aug 15, 2018.
By The Informer on Aug 15, 2018 at 5:24 AM
    1. Richard Knapp
      Richard Knapp Active Member
      OXY 3 - Tareq Alsaadi Edition 2018 – The evolution of a legend!
      Designed by Oxy Heli and Lynx in cooperation with Tareq Alsaadi, for all of us that love Tareq and Oxy Heli!.
      From the Oxy Heli beginning, Tareq was and is, fully involved on testing and suggestions. Thanks to his superior’s pilot skills and heli experience, he returns the best flight reports necessary for the Oxy Heli project evolutions.
      Since Lynx Heli Innovations was born in 2005, Tareq along with Luca Invernizzi and all the Lynx Team, started to work together in order to release special products and optional parts.
      In 2015 the First OXY 3 Tareq Edition went released and was an amazing success… Now after tree years, Oxy Heli and Lynx in cooperation with Tareq Alsaadi proudly introduces the new OXY 3 2018 Tareq Alsaadi Edition.
      Let me say without hesitations: Oxy 3 Tareq Edition 2018, the evolution of a legend!
      Many of you confess by the interest for the improvement of the new Oxy 3 TE, but more ask: “How was possible to improve a product already perfect?”
      Honestly specking, we also was amazed by testing the newly designed OXY 3 TE.
      Tareq and Luca worked on advanced heli specification, and the result after over 10 months of hard work is now easy touchable… not just for beauty but especially in flight.
      Major changes applied compared the OXY 3 Tareq Edition 2015:
      1- Main Blade: Tareq request more precise and efficient main blade.
      In response of this request, Luca started serious design cooperation for Zeal, along his experience and engineering skill. Luca defined an innovative skin blade Airfoil, combined with a Variable Profile geometry that optimizes the airflow speed along the blade length, reducing drag effect giving the “clean and precise” feeling Tareq feedback noted he was looking for. This resulted in the new design named Vari-Pro (Variable Profile). This improved efficiency over the old 285mm blade, resulted in the new inedited 287mm Zeal Vari-Pro Blade. All of these changes gives an obvious and touchable improvement of fly feeling effect.
      2- Simplicity to Efficiency… Because we don’t listen only to Tareq, but also the OXY community comments drive our future... Than based to the first OXY 3 Tareq Edition, other new features were added to make all manual operations easier.
      - Main Gear Jesus Bolt: Those who have an OXY 3 already know what we are talking about.. YES, we did! New Design, were no pliers are necessary on the lock / unlock operations. Already used and approved on our OXY 4 a special OEM Nut called H2-M2 helps dramatically assembly and service operations.
      - DFC Linkage Rods, some of you as us, probably experienced a nasty feeling discovering after crash, the impossibility to reuse Main Grip, with the DFC fastening screw snapping off in it!
      In the new OXY editions, we introduce a “clever” and innovative system with superiors fastening and kinetic features. So in case of hard crash, assure the integrity of the Main Grip with the possibility of easy and fast service of every single DFC / Head and parts.
      Simple detail made big improvements!
      3- Improved CoG (360 degree Center Of Gravity): Extra battery volume, better visibility and “Muscle” Kit Sexy Look. Improve on perfection is not easy, but Tareq’s request push us for the excellence even farther!
      - New frame design, combined with a new profile canopy is the answer.
      - New paint schema with Tareq’s loved “Hi Dubai” hand logo and matched painted boom adds detailed and esthetics touch.
      - Weight Reduction, thanks the new components: Landing gear, frame and canopy over 10g overall weight saving compare the previous edition
      4- Tail System Efficiency: For Oxy Heli the Tail was and will be the most important Heli feature to handle.
      - The New OXY 3 Tareq Edition feature new tail components and tail ratio. With all new components, together with the improved efficiency we improved the vibe suppression, the holding and the wear resistance.
      OXY 3 - Tareq Alsaadi Edition 2018 – Specifications List:
      For the best pilot, just simply the best features!.
      FRAME AND CANOPY:
      - New canopy design, reduced volume and aggressive look. 100% 3K Carbon Fiber Epoxy construction: strong and lightweight construction. - Tareq Designed ‘Hi Dubai” logo and paint schema by Canomod Production.
      - New Frame Design improves CG, battery volume capability and stiffening.
      - Triple Main Shaft Bearing Block Support System.
      - Ultra-Light and flexible landing gear - Carbon Plastic copolymer based material
      - CNC POM Copolymer main gear with innovative Jesus H2-M2 Nut System.
      - Motor Mount / Upper Frame CNC Sandwich Stiffener System Lock.
      - CNC Aluminum Tail Boom Clamp CNC Sandwich Stiffener System Lock.
      - Carbon / Copolymer Anti-rotation guide.
      - All aluminum parts with special surface finish and Racing Anodize color (orange / black).
      HEAD SYSTEM:
      - New main blade Carbon Fiber Zeal Vari-Pro 287mm Orange Touch.
      - DFC Head System with CNC Aluminum Arm and innovative fastening lock system.
      - All aluminum parts with special surface finish and Racing Anodize color (Orange / Black).
      - Optional FBL System Head available, sold as optional.
      TAIL SYSTEM:
      - Polymeric OXY HELI Profile Boom System.
      - New improved Tail Grip and Tail ratio System.
      - CNC Aluminum Tail Servo Support.
      - Reinforced Tail Case with Carbon Fiber and Aluminum CNC parts.
      - CNC Aluminum tail Bell Crank, with innovative anti-rotation Slider Ring system.
      - Plastic Black 50mm Tail blades.
      EXTRA PART AND ACCESSORY COMES WITH THE KIT:
      - Oxy Heli wrenching Towel.
      - Swashplate leveler tool.
      - 11T and 14T pinions.
      - Vertical fins colored stickers
      Tareq Alsaadi OXY 3 Flying Set-up Part List:
      - Main / Tail Blade: 287 mm Zeal Carbon Main Blade – Oxy 50mm Plastic Tail Blade
      - Tail Blade: 50 mm Tail Blade.
      - 4s 1500 or 6s 1000 – Battery.
      - For 4S Battery Configuration X-Nova Tareq Edition 2216 – 4100 KV Motor.
      - For 6S Battery Configuration X-Nova Tareq Edition 2216 – 2600 KV Motor.
      - Hobby Wing 40 / 50 A ESC.
      - Neo FBL System.
      - 3 x MKS DS95 cyclic servo and 1 x MKS DS95i Tail servo.
      - 4500 and higher Head Speed – Pitch +/-14 – Cyclic +/-11.
    2. Richard Knapp
