Help Tightness Of Main Blades
Discussion in 'Align' started by hgnimda, Apr 20, 2014.
By hgnimda on Apr 20, 2014 at 12:55 AM
  1. hgnimda
    The question often perplexes me. If loose blades cause blade strikes is there any disadvantage to screwing down the blades really tight? I mean would it not make sense to really tighten all main blades before flight?
    1. Geena
      The disadvantage of tightening them down excessively tight, is that the blades then won`t be able to find their center when they spool up. Which will most likely result in vibrations due to the head being unbalanced. I always tightened mine just enough to get just a little resistance when folding or unfolding them, and no problems so far. :)
    2. simon
      I go for fairly tight, really tight if you are brave enough for a blade stop (apparently).
    3. ToddMoriarty
      ToddMoriarty Well-Known Member
      You actually can tighten blades to the point they crack. I run mine pretty tight. I can hold my Heli at the blade root and shake it without collapsing. As far as not finding center: There is a lot more centrifugal force exerted on blades than you think. Hundreds of kilos in a 700
    4. 3dmick
      3dmick Well-Known Member
      I do mine up thight I have had my old 700e boom strike with old head that was befor the Dfc stuff
      so there is no way they can fold when doing auto bailouts or the wall or any
      Thing that unloads the head
    5. Manyc
      Yeah and you never do walls... If you haven't boom striked you 700 yet is a testament to doing then up tight
      Citizen#024
    6. 3dmick
      Yeah I love the sound of the head over speeding the EsC love doing the wall a big 180amp spike blade fart hahahahaha
    7. Radar
      Radar Moderator Staff Member
      Well I have gone through all different tightness with my blades. Used to run them very tight up until recently, like Geena said I have an E7 at 1850 would shake quite a bit. Loosen the blades and no more shake. I just run my blades firm now and have never had a problem.
    8. HungryHungryHippos
      I wouldn't worry too much, someone will always tell you that you have your blades too loose, then 5 minutes later someone else will walk up too your helicopter and tell you have your blades too tight.
    9. HeliGods
      If you want the blades tight, make them firm then hover at full head speed so they find center and then land, walk over and screw them down real tight and you will be set for the day, if you get a bit of shaking, just loosen a tad.. .. Tight blades are needed for things like the WALL, or you may very well boom strike, Just ask Min ..
