Video Trying Out The New Futaba T6k
Discussion in 'The Chat Room' started by alex jr, Apr 22, 2016.
By alex jr on Apr 22, 2016 at 2:41 PM
  1. alex jr
    alex jr New Member
    Hey guys I'm trying out the new futaba 6k thanks to futaba Australia. This radio is a small, compact and affordable radio that packs a punch with telemetry. It features the new r3006sb telemetry reciver. One of the amazing features of this radio is if u have subs programable servos u can hook them up and read the ids and program them for what you want. I also like the fact that it has a nice backlit display and the menu is so easy to use, 4 pages and you have everything u need. The new r3006sb rx is nice that it has sbus 2 so that u could for example hook up a castle telemetry link in your helicopter, and have all your castle's information I front of you.
    This radio is suited around the beginner and multirotor type of hobbiest. It's cheap at a price of $280aud at Perth Rc.
    Here is a video of me fly with the t6k
    Here is some more info for futaba
    System features
    S-FHSS/T-FHSS selectable
    Telemetry system (T-FHSS) with data speech function for monitoring receiver battery voltage, external voltage, temperature, RPM, altitude and variometer
    Built-in antenna
    S.Bus/S.Bus2servo setting functions programmable through the transmitter
    Preset vibration alarms
    30 model memory
    8-character model/user naming
    Programmable mixes for airplanes, helicopters, gliders and multi-rotors
    Digital trims with variable step settings
    Adjustable stick length and tension
    Changeable switch/VR position and AUX channel function
    Throttle position warning
    Backlit 128x64 DOT LCD screen with adjustable display contrast
    Software updateable through the CIU-2
    Screen Lock
    Earphone/S.Bus/Trainer jacks
    Assignable switches (three 3-position, one 2-position)
    Range Check
    Program navigation bay with jog dial, +/- pads and end pad
    Data reset
    Model copy
    Selectable model type
    Fail Safe
    End Points
    Trim/Trim Resets/Trim Steps
    Sub Trim
    Servo Reversing
    Parameter functions
    Servo monitor/Test
    Wireless model data transfer
    Timer-System and Model (Up/Down)
    Trainer system:
    The R3006SB receiver can use S.Bus as the main link/communication to the servos or a combination of S.Bus and the conventional outputs together. It features 6 standard PWM outputs in addition to S.Bus and S.Bus-2 outputs.Features bi-directional communication with a T-FHSS Air Futaba transmitter using the S.BUS2 port. Using the S.BUS2 port with an impressive array of telemetry sensors may be utilized.
