Turnigy Fabrikator 3d Printer
Discussion in 'Industry News' started by hgnimda, Apr 22, 2015.
By hgnimda on Apr 22, 2015 at 3:34 PM
  1. hgnimda
    Will 2015 be the year that 3D printers become ubiquitous? HobbyKing is out to make that a reality with the release of their Turnigy Fabrikator. Touted as the best value for money printer on the market, this quality 3D printer includes many of the features of printers costing three times as much and makes 3D printing available to anyone with a computer. Whether a user is into planes, multi-rotors, cars, boats, helicopters, robotics, trains or even anime figurines, the Fabrikator may very well become their most versatile tool. Can’t find that rare part for an old model or want to modify an existing component? Now a modeler can simply print what they want, when they want it.
    The Turnigy Fabrikator uses ABS and PLA filaments, available from the network of HobbyKing warehouses. Say goodbye to the days of setting up a job on the the printer at bedtime and hoping the job is finished by morning. This unit can print high quality finishes at up to at 150mm per second. Features like a solid frame, super stable quad rail supported print plate, high quality NEMA Class motors, removable glass print platform and twin belt Y axis drives make for accurate jobs, with no need for constant mechanical adjustments. A series of instructional videos guide new users through initial set-up of the printer, while a dynamic and living trouble shooting guide helps a user work through any difficulties encountered. Assembly does not require technical prowess and can be completed by most purchasers in less than six hours.
    Features:
    • Ball bearing liner rods
    • Rolled lead-screw with anti-backlash drive
    • Phenolic heat stabilized bed W/removable Glass print area
    • Heated print bed
    • NEMA 23 and 17 motors
    • 4 rod supported print plate for high speed printing
    • 6 sided full printer support for high accuracy
    • SD card cable free printing|
    • PLA and ABS filament compatible
    • Top feed anti-bind spool feed
    • Twin print cooling fans
    • 2A Heatsink stepper drivers with active cooling
    • 220~110V A/C compatible
    • Homing and Limit switches
    • Full LCD GUI with on the fly tuning
    • Large 150x150x100mm print area
    • Dual bearing supported twin belt Y axis drive
    • Heavy Duty 12Volt 29Amp Power supply
    • Open Source control Architecture and support
    • Full Parts support and future expandability platform
    Specs:
    Overall size: 360x400x600mm
    Print size: 150x150x100mm
    Nozzle diameter: 0.4mm
    Filament diameter: 1.75mm
    Print speed: up to 300mm/sec
    Print platform: Phenolic heat stabilized bed with removable glass print platform
    Filament type: ABS and PLA
    Required:
    Filament
    For more information or to order, click through to HobbyKing.com
    Continue reading...
      This will be the end of CHINAs manufacturing dominance!!!
    2. feral
      Aint cheap theres a few around that are a bit better for bugger allore cash
      One day they will be able to manufacture using most materials. Imagine that, design a chopper on screen and press the print button!!!
      man have you seen the 3d printed jet engine?
      Saw it on facey a few weeks back runs like a swiss clock
      No way.... A jet engine made from a 3d printer.... Amazing!
    6. simon
      That's high end 3d printing that uses scintered printing and it prints metal (yer baby), but they are still in the the 100,000's and industrial power.
    8. simon
      It will be a while before turnigy brings out one of those
    9. utrinque
      Most funny part is that we will download parts as flies instead of buying them fabricated, no shipment costs, ability to modify them before printing, we could share our open projects with others.
      Disadvantages:
      - we can not print vital heli parts: bearings, gyro, ESC, servo, motor, receiver.
      Actually MEMS gyro sensors are product of nano 3D printing but such "printers" are not hobby grade.
      http://www.suss.com/en/products-sol...MRGS_6CtCXbt_khViY4IP72pVHZjXJBu9oRoCGOzw_wcB
