Which Tail Servo Now?
Discussion in 'The Chat Room' started by MadBird, Sep 29, 2014.
By MadBird on Sep 29, 2014 at 10:45 PM
  1. MadBird
    It was a glorious morning, so I headed off to work early with the ambition of putting a couple of tanks through the N7 to start the day off.
    During my radio check I noticed that the tail servo wasn't responding to any stick inputs. I had a bit of a play around with it on the bench, but in short, the RJX tail servo has shiz the bed and no longer wants to play the game after only 25 or so flights.
    Soooo what does everyone recommend as a good mid level tail servo? I'm only a sport flyer at present so I don't need to spend a fortune, but I would like to buy something that is reliable and will last longer than 25 flights.
    Any and all advice will be considered....
    1. Jeff_Bradley
      Bk's seem to be a good servo, however I prefer the HV Futabas.
    2. Manyc
      I'm about to try out the BK Tail... BK Cyclics are pretty awesome... but I have always before run futaba on the tail.. will see...
    3. Geena
      I have been been running an MKS HBL 980 on the tail of my TSA 600N Platinum, and I love it. The TSA 600N Pro and the Goblin 570 both have Align DS655s, which have worked flawlessly.
    4. Min
      Futaba BLS-276
    5. feral
    6. MadBird
      The BK's look like a well spec'd , well priced option.
      The BLS276SV appears to be a BLS256HV with metal gears and are SBUS2 compatible, will they work with my VBar using spekky sats? Can get these for a pretty good price atm.
      The MKS seem few and far between here in Aus.
    7. Min
      BLS-276SV is still nylon gears but is faster than the 256HV
    8. MadBird
      Min are you sure that the gears are nylon? The specs say MG. http://www.futaba-rc.com/servos/sbus.html
      Sent from my Electronic Appendage
    9. Min
      I've opened up my one and they are certainly not metal. They don't need to be at 5KG torque, metal will just add unnecessary weight.
    10. MadBird
      So after doing some more research the BLS276Sv's appear to be more like a hybrid gear train. At $140 these are highest on the list atm.
    11. Manyc
      I have used both the 256 and 276 and both are awesome tail servos
    12. The Dude
      awwwc shiz... tail servos, dam that's what that spot is for, no wonder my tail spins out of control on take off !! lol
    13. Manyc
      Nah man that because your always pushing full rudder either left or right... there be no stationary hover in your repertoire..
    14. MadBird
      I needed to stop procrastinating or I wouldn't get back in the air by the weekend, so I went for the 276 which was cheaper than if I had of replaced the shagged RJX like for like.
      Thanks for everyone's input.
