Build Info Do Better Bearings Really Make A Difference?
Discussion in 'The Chat Room' started by hgnimda, Apr 20, 2014.
By hgnimda on Apr 20, 2014 at 1:42 PM
  1. hgnimda
    hgnimda Ray - Administrator Staff Member
    Ok you can buy bearings http://www.bocabearings.com/ and several other high quality type bearings. Do these really have an advantage over the standard bearings supplied in RC Helicopters today? If so what can i expect by using better bearings.
    There are also Ceramic Bearings as well. Are these of any use compared to normal bearings?
    1. 3dmick
      So they must last more then 2000 flights or there just not good enough is that right mr ray
    2. hgnimda
      Well where do i buy 2000 flight bearings that dont wear and cost very little?
    3. 5Fidy
      5Fidy RIP Jason
      In imaginary fantasy land of with the magical fairies
    4. HeliGods
      I can say first hand.. they do make a diff.. less slop over time.. hold up better in a crash and keep running smoother for longer.. jap bearings are the best..
      Answer is yes... trend to last longer and built with tighter tolerance... I notice a difference when compared to align or msh bearings... with ceramic they last longer and are more efficient but are far more brittle and will break easier... I would not use ceramic in a heli
      Citizen#024
    6. hgnimda
      Thats my life! lol
    7. TrAuMaChAsER
      TrAuMaChAsER Member
      Do you guys oil your bearing? And how often? I put a little high performance bearing oil in mine recently hoping to make them perform better and it seemed to work for like a week then I started getting like scratchy sounds from them that I didn't hear before I oiled them. I don't know if it was the oil or if I just shouldn't of messed with them.
      Sent from Hell via a nano cpx....
      Depends on the bearings... most bearings are sealed, and should have enough grease to last its "lifetime" if you use oil, it will push out the other grease, and since oil has a lower viscosity it will come out of the bearings, and you will have to oil them pretty regularly...
    9. Jeff_Bradley
      I have the greaser and it seems to revive tired bearings
    10. Collie_Farmer
      Collie_Farmer Active Member
      I just bought the kde thrust bearing for my main shaft...every time I go to do maintenance those bearings are shot
    11. HeliGods
      What heli is that on ?
    12. Collie_Farmer
      Align 600 pro dfc...basicaly you need the whole kde upgrade line to make it a decent heli..the kde hub is next the align head wobbles on main shaft due to it only has 1 jesus bolt and no clamp bolts
    13. Collie_Farmer
    14. HeliGods
      KDE .. Make nice stuff ..
    15. Collie_Farmer
    16. Manyc
      Not sure if I would rate kde or lynx bearings much higher than align, msh etc. Was more referring to places specialising in bearings bocca bearings or rcbearings. I got a bucket load of rcbearings in and I was pretty impressed with the quality and price.
      Citizen#024
    17. Geena
      I have been oiling my bearings with scorpion motor bearing oil about every 3-4 flights. I don`t know if it`s doing much if any good, but it certainly can`t hurt. :)
    18. Collie_Farmer
      Boca bearings are the shiz..I got the kde set cause they added thrust bearings. .I cant run excessive oil due to I live in the desert
      Hi @Geena , I think as @Manyc said, once you start oiling you have to keep oiling. So i think you would be fine based on that.
