Align 600 Booster Kit, Cc Esc Gov Settings
Discussion in 'Align' started by Collie_Farmer, Mar 27, 2014.
By Collie_Farmer on Mar 27, 2014 at 3:35 AM
  1. Collie_Farmer
    Collie_Farmer Active Member
    does anyone have the CC gov settings for the align 600 booster kit..i downloaded the 700mx settings from CC and seems too be doing alright..but I haven't pushed it yet and a first time gov user,i usualy run flat curves
    1. Collie_Farmer
      So I talked to align and they have recommended the 800 settings.. here is that link
      http://shop.align.com.tw/Instruction%20for%20setting%20the%20ICE2%20HV%20120%20governor%20mode%20with%20800MXEN.pdf
      I live in higher elevation and have got better performance so far from the 700 settings and have found that a lot of people are using the 700 setting a lot. the major difference is the gain on the 800 is about 10 & the gain on 700 settings is 16
      so here is the link to the 700mx 530 kv settings.. hope you guys find this hopefully due to I found a lot of dead ends researching this myself
      http://www.castlecreations.com/support/align_heli_settings/align-700e-700mx-530kv.html
    2. William
      William Active Member
      I have a 700MX 510 I might want to try in my 600, mine is the old school 600, pre ESP, that I converted to 12S years ago. I used the 630KV Scorpion, but that motor is old now, it is the pre HKIII, so I have most of the kit that is the power boost kit, main gear, pinion, motor, KDE motor mount, and adjustable boom block kit.
    3. William
      I forgot to add, I have a Jive, otherwise I would share my settings with you... I may have saved the settings from an older setup on a Ice 80HV I had on a different 600, if you want me to look?
    4. Collie_Farmer
      I got the settings now..thank u though
    5. William
      Quite pleased with the 700MX 510 nice smooth power, not monster power, just clean steady hum coming from my beasty now!
    6. HeLiAdIc
      HeLiAdIc Member
      Love it great stuff, my type of flying being an old man and all.
      Awesome flying again dude, love the floyd as well. Your flying field is awesome..
