Info New Fbl On The Way
Discussion in 'The Chat Room' started by Manyc, Jun 23, 2015.
By Manyc on Jun 23, 2015 at 8:07 PM
    Stole this from archeli.. Who got it from heli freak.. Either way in very interested..
    Thomas (the man behind the Brain/ikon) split with MHS and has been working on a new project and has developed two new fbl controllers which will soon be released, the Neuron and it's big brother which hasn't been named yet. With some updated hardware and Thomas's programing skills this promises to be a fbl to keep an eye on. This is the info from HF
    NEURON<
    Hardware :
    Latest generation, 9 axis sensor (MPU-9250)
    Latest generation STM32F4 microcontroler with floating point unit
    Rock solid power stage (no more sat locks) up to 8.4V
    Very small : 23.15 x 34.5 x 13.6 mm
    6.7g weight
    External USB connector for more installation flexibility (cable and adapter provided in the box)
    Unplug the USB adapter and you can plug a Bluetooth module instead (same cable).
    3 bottom case colors to customize your unit (time limited offer)
    Every connector is electrically protected
    3M Very High Bond double sided pad provided
    Features:
    Handles (via different firmwares available to everyone without additional cost) all size helicopters, quads and planes with the same level of performance.
    Built-in RPM governor
    One built-in sat connector with smart bind (no bind plug nor PC needed to bind)
    You can connect a second sat via an adapter
    Handles all serial output receivers (HoTT, SRXL, SBUS/SBUS2, JR XBus Mode B and Mode A, PWM sum of course, plus DSM2 and DSMX sats), one wire per channel receivers are supported through an adapter (e.g. SBUS)
    Software:
    Extreme performance, incredible feeling
    Setup and tuning as simple as possible
    FREE setup terminal on PC (USB and BT) and Android (BT), all features availables, including firmware update, load/save configuration (compatible files between PC and Android)
    iPhone software is work in progress, via a specific Bluetooth Low Energy device available later
    Receiver auto-configuration, the unit detects the receiver type and configures automatically the channel assignment, throws, neutrals, reverses, etc at each startup.
    Each firmware type (quad, heli, plane) has its own GUI, software user interface is totally adapted for each model type
    Upgrading firmware doesn't mean upgrading PC / Android software. You can upgrade one unit's firmware and keep another one on a previous firmware, each one will have the adequate user interface.
    RPM governor auto-configuration, ne need to set gear ratio, etc. just plug the sensor, setup a flat throttle curve and fly (both nitro and elec)
    Rescue mode for helis, with pitch management
    Self level mode for quads and planes
    Introductory pricing: 130€ (approx $150)
    Available: VERY SOON (production already started!)
    AND BIG BROTHER WITH NO OFFICIAL NAME YET
    ULTRA POWERFUL latest generation microcontroler STM32F4 with floating point unit
    10 connectors for a high power installation and plug tons of servos
    2 smart bind sats connectors
    Support for H4 helis, hexacopters, octocopters, planes with multiple servos per function, etc.
    Built-in barometer (altitude hold)
    Support for external GPS (position hold)
    Built-in FLASH memory for complete logging of any flight parameter, and analyse them directly in the software
    Available in: a few months
      Damn will edit it properly later
      Sent from my SM-G920I using Tapatalk
    2. MadBird
      Very exciting news indeed. If it's as functionally cool as the description reads then this could shake things up a bit in the FBL world!
    3. iggy
      Sounds very good. Hopefully it will be.
    4. MadBird
    5. Geena
      Wow! This looks promising. From the specs, they`ve pretty much thought of every desirable feature for a FBL to have.
      WHAT? Altitude hold? With that setting it means there could be a hard deck. BUT what is "extreme performance" and "incredible feel". hmmm only by flying can you truly determine. What a GREAT find @Manyc . Are you sure your not the informer in disguise?
    7. Overspeed
      Overspeed Member
      Hard deck would be very cool, but I don't think crash would approve
    8. Min
      Is it just me or does this look like a cheap USB stick? lol
      • Funny Funny x 1
    9. MadBird
      I'm sure these units will be little rippa's like the Ikon/Brain's are. They won't be replacing my Spartans though.
    10. Manyc
      Course not.. Found reference on the other forums.. As mentioned at the start of the post...:p
