Well i recieived my goblin 380 on Saturday the 9/5/15 at around 11.00 am from zen RC. After one hour of gasbagging with @ZEN RC we decided it was time to start building at 12:00 am.
FIRST STEP.... File down all the edges of the frames using sandpaper.
The frames went together really easily. The most significant thing i should point out was that you should make sure you install the battery clip. Small part easy to forget.
I installed the bottom plates and the servo mount as suggested in the manual. If you dont insert the servo now, you will have to remove the rear servo mount at a later stage.
One of the things about this build is how well laid out the components are and how impressive the instruction manual is.
I brought the optional landing gear... the mounts here are non standard. The front landing gear mount is a bit tricky to figure out so inspect the photo below.
6 Hour Goblin 380 Build - Start To Finish
Discussion in 'SAB' started by smakmeharder, May 11, 2015.
Page 2 of 2Page 2 of 2
