I want to share with you details regarding my old project and provide recipe for building 700 lighter than TDR.
It:
- is reliable - I fly it since 2012, it has 3 main shaft bearings blocks (more than Align 600 PRO)
- is proven - I build 3 or 4 of them
- is cheap - it is Frankenstein heli built around HK600GT frame with some Align parts in key areas
- it can use 4Ah lipos in 12S setup providing 5 minutes flights.
- floats great on low RPM, on high RPM becomes a rocket.
- recently I succeded to convert it to night flight rig and will share details how cheap this can cost
- it is quiet due to low RPM and low disk load if main shaft bearings are in good condition
- offers most convenient front battery mounting - I will show how to secure lipos safely and I bet weight vertical distribution is better than in lipo tray mount design.
List of components I use and recommend:
- HK600GT CF frame halves - cheap as dirt and stiff enough for 700
- RJX 50 (600 class for 10mm main shaft) FBL head
- Align 600 PRO rear "tail cage" with double support slider
- Two Align main shaft blocks and one "third" alu block from HK600GT
- HK600GT main shaft - fits third bearing block (can be shortened for better performance and lowering the FBL head, more details later)
- Align mod 1.0 slant gear used in Trekker "unbreakable" in low weight 700. It offers wide range of pinions and gearings having 112-118T
- Align 600 PRO OWB block (recommended OWB is from HK600GT, it is much stronger than Align OWB)
- Align 600 PRO slant autorotation gear
- Align or cheaper Assault tail boom and (have to be shortenned by 40mm to fit TT lenght) and TT
- Align front plastic tail boom mount from 600 ESP (PRO version is wider and does not fit directly)
- Align 600 PRO front umbrella gears
- HK600GT alu frame parts or plastic version from Align
- wide range of landing gear options starting from HK600GT, Align 600 PRO, Assault 700 or Align 700 (F3C version is lower than others)
- galantery (HK600GT or Align: motor mount, pushrods, tail supports, boom tail supports mount, etc.)
Recommended electronics (cheap but proven and very reliable):
- Kbar gyro
- Power HD servos (or rebranded TGY)
- my favourite servos I use in 800: TGY 805 and 815 (BL, titanium gears) - those are rebranded KST BL 805 and 815
- SK3 700 480kV motor - lower weight than Gartt motor but les reliable due to weaker bearings
- my favourite Gartt 4.2kW or newer 4.5kW 530kV motor
- YEP 120A HV
- I use FrSky Taranis radio with or without telemetry
- YEP 20A SBEC - powers my 800 electronics
- $30 Turnigy 700mm blades - newer failed on me for years
- alternatively RJX 690 or 700mm blades
ADVANTAGES:
- very cheap 700
- cheap parts available everywhere including clones, upgrades from KDE, Quick etc. cheap tail boom and TT from Assault/Gartt 700 etc.
- uncomparable feel of low weight 700
- direct to swash setup (not possible in 600 ESP frame without modification of the frame, but posisible)
- adjustable motor mout with wide range of possible gearings to fit your motors kV
- can use my favourite $4 white, plastic HK600GT canopy
- keep in mind you can put any fancy electronics in this airframe but it is not always good idea if you want to keep low weight
WEAKNES:
- at very high RPM front umbrella gears can fail. It never happened to me in flight and I will show you solution to solve this problem. I will provide more details. For smack heavy setup Assault 700 is better option if you put some Align parts.
I plan to add photos and videos in folowing posts and describe in more detail build process with detailed recomendations how to setup this heli. Stay tuned.
(Original thread is available on HF. Google: "for me Align wins" In 2013 $1000 700 was relatively cheap. Now you can build it cheaper with better electronics and motor.):
700 Lighter Than Tdr
Discussion in 'HobbyKing' started by utrinque, May 31, 2015.
Page 3 of 3Page 3 of 3
