Riddle Tag
Discussion in 'The Chat Room' started by mr_squiggle, Oct 27, 2014.
By mr_squiggle on Oct 27, 2014 at 9:16 PM
  1. mr_squiggle
    Poor old @CrashMinion wanted a break from having to come up with all the riddles. So here's a new thread where whoever gets the riddle correct has to come up with the next one.
    Here's the first one. I'll provide some clues if required, but have a think about it first.............
    I'm number 3 and I'm in charge. What am I?
    Fire away!
      NOOOOOOOOOOOOOOOOOOOOOOO..... sob sob sob....
    2. mr_squiggle
      Y is engine rpm and X is battery voltage.
    3. mr_squiggle
      There, there @smackers, it'll be ok. Wipe your nose & have another go.
      Sound like threadlocker to me
      Ok...@mr_squiggle... I was so confident.. sob... I get annoyed if i apply too much money to my chopper, but too much power is never a problem ?
    6. Glen
      Glen Active Member
      Y is directly measurable, X is a derivative.
    7. Glen
      Glen Active Member
      You dont know how close you are there! :)
    8. Glen
      Glen Active Member
      You can snap a bolt with NO x
      What is X?
      Patience? lol... sorry discount that..
      No Nuts? sorry discount that too...
    11. smakmeharder
      control? restraint?
    12. smakmeharder
      OK OK OK... X = Control and Y = Power You cant have control if the heli isnt flying. Power is needed to have control!!!
    13. Glen
      Glen Active Member
      But Y is used to calculate X
    14. Glen
      Glen Active Member
      Y is greater at the main shaft than at the motor. But X is the same at both.
    15. Glen
      Glen Active Member
      Saving this hint
    16. MadBird
      Tail gain and tail ratio?
      Sent from my Electronic Appendage
    17. MadBird
      Didn't see post 174. X has to be power. Y is hmmm torque?
    18. Glen
      Glen Active Member
      We have a winner.
      But you still have to answer why X can very with Y as a constant :)
      Your up..
    19. Glen
      Glen Active Member
      Easy one this time.
    20. MadBird
      Ummm well yeah... Me thinks torque is the force needed to cause an object to rotate. The force required to maintain said rotation (governed head speed) is constant, but due to varying loads on the drive system (cyclic, collective and tail loads) a variable power source is needed to produce the required force. This is why current draw from your flight pack or throttle position on a nitro are constantly changing (power) to maintain the set head speed (torque).
